NetApp Stage KB
CIFS clients access slowly with FPolicy disconnecting repeatedly
2
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP
  • CIFS
  • FPolicy
Issue
  • CIFS clients are slow with enabling FPolicy
  • High latency is observed by PA
  • Disable FPolicy resolves CIFS client slow
  • EMS shows the following error:
Mon Jan 04 12:09:45 EST [example: fpolicy: fpolicy.server.connectError:error]: Node failed to establish a connection with the FPolicy server '10.1.1.101' (reason: 'Connection to FPolicy server is broken(EPIPE) received.').
Mon Jan 04 12:09:45 EST [example: fpolicy: fpolicy.server.disconnect:warning]: Connection to the Fpolicy server '10.1.1.101' is broken ( reason: 'FPolicy server is removed from external engine.' ).
Mon Jan 04 13:06:11 EST [example: fpolicy: fpolicy.server.disconnect:warning]: Connection to the Fpolicy server '10.1.1.101' is broken ( reason: 'FPolicy server is removed from external engine.' ).
Mon Jan 04 13:06:36 EST [example: fpolicy: fpolicy.server.connectError:error]: Node failed to establish a connection with the FPolicy server '10.1.1.101' (reason: 'Select Timed out.').
New to NetApp?
