NetApp Stage KB
Are long Consistency Points (wafl.cp.toolong) normal?
4
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 7-mode
Answer
  • If no performance impact, then yes, the occasional long Consistency Point (CP) is normal and expected.
  • It is recommended to check if latency is higher than expected.
  • Sometimes long CPs occur frequently and a case may be opened to investigate further if the cause cannot be determined.
Additional Information
  • ONTAP can do several background tasks in CP and will use the longer CP time:
  • If ONTAP is more idle, long CPs are expected to allow more priority for background work or write bursts.
  • CPs happen asynchronously of the write path.
    • Writes are acknowledged when written to NVRAM on both the local and partner node.
    • Latency is unaffected as writes can be buffered until CP completion.
    • This means latency will not be impacted as data stays in RAM for 30 or more seconds due to low write workload.
    • ONTAP 9.15.1 includes some enhancements so this background delay will be less, however this is not necessary to upgrade immediately for a fix due to being expected behavior.
