NetApp Stage KB
CONTAP-82625: MetroCluster configuration replication failure Internal Error: Failed to verify if the volume has blocks in the capacity tier
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Issue
When applying a QOS policy to a DR replication on a flex volume the DR replication fails
Autosupport alerts generated for DR config replecation failed;
HA Group Notification (DR CONFIG REPLICATION FAILED) ERROR
In events logs some of the bellow errors may be seen;
Failed Reason : Apply failed for Object: volume Method: baseline. Reason: Internal Error: Failed to verify if the volume has blocks in the capacity tier.
QOS_VOL_CA_TPF_CHECK_FAILE
New to NetApp?
