NetApp Stage KB
CONTAP-377586: REST API documentation that provides calculation to determine the CPU utilization percentage is incorrect
1
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Issue
  • The ONTAP REST API reference documentation provides a calculation to determine the percentage CPU utilization for the node:
Raw CPU Utilization for the node. This should be divided by the processor_utilization_base to calculate the percentage CPU utilization for the node
  • This calculation is not accurate and can return results of over 100% utilisation in applications like Checkmk.
  • This change updates the above definition with the correct calculation in the YAML file in ONTAP.
  • A documentation CONTAP will also be opened to update the following document with the correct calculation: Retrieve the nodes in a cluster
  • Checkmk has also released a fix with the updated formula, which will fix the CPU reporting issue. Please see this link for the fix
New to NetApp?
