NetApp Stage KB
Data ONTAP 8.2 does not support Flash Cache for the current installed base of FAS/V3210 and FAS/V3140 (7-Mode or clustered Data ONTAP)
1
Visibility:
Votes:
0
Category:
clustered-data-ontap-8
Specialty:
HW
Last Updated:
Applies to
  • FAS3140/V3140
  • FAS3210
  • Clustered Data ONTAP 8.2
Issue
FAS/V3210 & FAS/V3140 systems with Flash Cache cards enabled and running Data ONTAP 8.1.x will not be able to boot if upgraded to the Data ONTAP 8.2 code base.
Note: You can use the "sysconfig -a" or "sysconfig -ac" commands to check the hardware installed on the system.
New to NetApp?
