NetApp Stage KB
Volume move operation is stuck at restarting
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP
Issue
  • Volume move operation fails to restart
  • The volume move temp volume is destroyed
Tue Nov 05 11:51:03 +0800 [node10: vv_config_worker01: wafl.vvol.offline:info]: Volume 'temp__1365__45890__volume-move@vserver:bec0ee6e-60ca-11ed-bc87-d039ea50d972' has been set temporarily offline
Tue Nov 05 11:51:03 +0800 [node10: vv_config_worker17: wafl.vvol.destroyed:notice]: Volume temp__1365__45890__volume-move@vserver:bec0ee6e-60ca-11ed-bc87-d039ea50d972 destroyed.
  • The command output:
::*> vol move show volume-move -instance
                            Vserver Name: vserver
                             Volume Name: volume-move
                    Volume Instance UUID: ad8d8e1d-39d4-11ef-9f72-d039ea4fe62e
                  Actual Completion Time: -
                         Bytes Remaining: -
                              Bytes Sent: -
                             Status Code: -
                       Completion String: -
            Specified Action For Cutover: retry_on_failure
              Specified Cutover Attempts: 3
           Specified Cutover Time Window: 30
             Time User Triggered Cutover: -
      Time Move Job Last Entered Cutover: -
                      Cutovers Attempted: 0
             Times Cutover Hard Deferred: 0
             Times Cutover Soft Deferred: 0
                   Destination Aggregate: n10_aggr_ssd_1
                        Destination Node: node10
                         Detailed Status: Volume move job restarting
Error: Retrieving on-disk attributes: The volume does not exist for the operation
            Estimated Time of Completion: -
               Internal Progress of Move: Volume move job restarting
                     Actual State of Job: Restart
                                  Job ID: 45890
                                Job UUID: 0230a704-9a64-11ef-9039-d039ea4fe57a
                           Managing Node: dsfsc03n01
                     Percentage Complete: -
                              Move Phase: restarting
                Prior Issues Encountered: 11/5/2024 18:51:05 : Getting volume move phase: No such file or directory
11/5/2024 18:48:30 : Retrieving on-disk attributes: The volume does not exist for the operation
11/5/2024 12:13:13 : Getting volume move phase: No such file or directory
New to NetApp?
