NetApp Stage KB
Takeover not possible: Resolution Guide
25
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Except MetroCluster IP solutions
Issue
Takeover not possible, as displayed in the error message:
::> storage failover show -node ClusterA-01 -fields possible
node         possible
ClusterA-01  false
Cause
Follow this resolution guide to locate the solution based on the reason which caused Takeover to disable.
Run the storage failover command to determine the reason:
::>storage failover show –instance –node <node_name>
Example:
::> storage failover show -instance
                            Node: cluster1-01
                    Partner Name: cluster1-02
                   Node NVRAM ID: 5######
                Partner NVRAM ID: 5#####
                Takeover Enabled: true
                         HA Mode: ha
               Takeover Possible: false
    Reason Takeover not Possible: Local node missing partner disks
Solution
  Click on the reason causing takeover to disable to get the solution KB
operator disabling takeover storage failover is disabled version mismatch
degraded mode (mailbox disks) interconnect errors disk shelf being too hot
NVRAM log not synchronized partner node halted after disabling takeover local node already in takeover state
local node about to halt mailbox disks are not healthy HA Interconnect down
local node missing partner disks
ONTAP Select
CVO
AFF/FAS
► Click to view Solution in Table Format
Message Solution
Takeover not possible: operator disabling takeover
storage failover is disabled Takeover not possible: both nodes in HA pair are not joined to cluster
version mismatch Takeover not possible: version mismatch
degraded mode (mailbox disks) Takeover not possible: degraded mode (mailbox disks)
interconnect errors Takeover not possible: interconnect errors
disk shelf being too hot Takeover not possible: disk shelf being too hot
NVRAM log not synchronized Takeover not possible: NVRAM log not synchronized
partner node halted after disabling takeover Takeover not possible: partner node halted after disabling takeover
local node already being in takeover state Takeover not possible: local node already in takeover state
local node about to halt Takeover not possible: local node about to halt
mailbox disks are not healthy Takeover not possible: Mailbox disks are not healthy
HA Interconnect down Takeover not possible: ONTAP Select: cf_diskinventory_sendFailed reason="HA Interconnect down"
Additional Information
N/A
New to NetApp?
