NetApp Stage KB
Remote Device ID not showing
1
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • CDP (Cisco Discovery Protocol)
Issue
  • Remote device ID information not showing in network port show output although the ports are online.
 node01::*> network port show -fields remote-device-id
 node             port remote-device-id
         node01   e0M  -
         node01   e0c  test01(FOC2422R0KT)
         node01   e0d  test01(FOC2031R4AT)
         node01   e0e  test01(FOC2351R00R)
  • OPTIONS log show CDP is enabled
cdpd.enable on
cdpd.holdtime 180
cdpd.interval 60
  • network device-discovery show output do not  report the issued port's remote device id
node01::*> network device-discovery show
Node/       Local  Discovered
Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
node01/cdp
             e0a    test02                    e0a               FAS8300
             e0b    test02                    e0b               FAS8300
             e0c    test01
                                              Ethernet1/10      N3K-C3132Q-V
             e0d    test01
             e0e    test01
                                              Ethernet1/10      N5K-C5672UP
             e0g    test01
  • VIFMGR.GZ log show remote device for issued port expired.
Fri Apr 15 2022 00:41:11 +09:00 [kern_vifmgr:info:6072] [0x810e73b00] [vifmgr_remote_devices_iterator::report_changes] remote device for port node01:e0M (cdp) is now test01 (active)
Fri Apr 15 2022 00:44:11 +09:00 [kern_vifmgr:info:6072] [0x810e73b00] [vifmgr_remote_devices_iterator::report_changes] remote device for port node01:e0M (cdp) is now test01 (expired)
Fri Apr 15 2022 01:00:01 +09:00 [kern_vifmgr:info:6072] [0x80bffcd00] [vifmgr_remote_devices_iterator::report_changes] remote device for port node01:e0M (cdp) is now test01 (active)
Fri Apr 15 2022 01:03:01 +09:00 [kern_vifmgr:info:6072] [0x80bffaf00] [vifmgr_remote_devices_iterator::report_changes] remote device for port node01:e0M (cdp) is now test01 (expired)
Fri Apr 15 2022 01:06:11 +09:00 [kern_vifmgr:info:6072] [0x80bffaf00] [vifmgr_remote_devices_iterator::report_changes] remote device for port node01:e0M (cdp) is now test01 (active)
  • Packet Trace to issued port show that node is sending CDPv1 advertisement and CDP-compliant neighboring devices not sending CDPv1 advertisement back.
New to NetApp?
