NetApp Stage KB
No compression savings in ONTAP 9.9 volume layer
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9.8 and later
  • Temperature Sensitive Storage Efficiency (TSSE)
Issue
  • Volume shows deduplication savings, but no space saved by compression:
::*> volume show -volume vol* -fields dedupe-space-saved,dedupe-space-saved-percent,compression-space-saved,compression-space-saved-percent
vserver  volume               dedupe-space-saved dedupe-space-saved-percent compression-space-saved compression-space-saved-percent
svm1     vol3                 111.6GB            7%                         0B                      0%
svm1     vol4                 184.2GB            10%                        0B                      0%
  • df command will always show in the compressed column
cluster1::*> df -h -S -volume tsse_test
Warning: The "-S" parameter is deprecated and may be removed in a future release. To show the efficiency ratio use "aggr show-efficiency" command.
Filesystem                used       total-saved    %total-saved    deduplicated    %deduplicated    compressed
/vol/tsse_test/          623MB             494MB             44%           494MB              44%            0B
New to NetApp?
