NetApp Stage KB
Is block temperature persistent across volume moves?
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Fabricpool
  • Tiering
Answer
No, block temperature is stored within aggregate metadata and will reset when a volume is moved to another aggregate.
Additional Information
  • Two Fabricpool aggregates are configured:
myCluster::*> aggr object-store show
Aggregate      Object Store Name Availability   Mirror Type
aggr2_fp       svm-s3-DST        available      primary
aggr4_fp       svm-s3-DST        available      primary
2 entries were displayed.
  • Volume vol_fp_moveme is hosted on aggregate aggr2_fp with tiering-policy set to auto and tiering-minimum-cooling-days set to 2. Data would get tiered out to the configured cloud-tier once it has not been read for at least 48 hours:
myCluster::*> vol show vol_fp_moveme -fields tiering-minimum-cooling-days, tiering-policy, aggregate
vserver   volume        aggregate tiering-policy tiering-minimum-cooling-days
svm1      vol_fp_moveme  aggr2_fp           auto                            2
  • Currently, all data is in Performance Tier, nothing is tiered out to myS3Fabricpool yet.
myCluster::*> vol show-footprint vol_fp_moveme
Vserver : svm1
Volume  : vol_fp_moveme
Feature                                          Used    Used%
Volume Data Footprint                          8.12MB       0%
Footprint in Performance Tier                  9.77MB     100%
Footprint in myS3Fabricpool                        0B       0%
  • WAFL cold data reporting (cdr) statistics show 2001 blocks with age of 0 to 2 days (001 days) old - expectation is it will be tiered out tomorrow:
myCluster::> set adv
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
myCluster::*> statistics start -sample-id mysample -object wafl_cdr_vol
Statistics collection is being started for sample-id: mysample
myCluster::*> statistics stop -sample-id mysample
Statistics collection is being stopped for sample-id: mysample
myCluster::*> statistics show -sample-id mysample -object wafl_cdr_vol -instance aggr_aggr2_fp_vol_vol_fp_moveme -counter blks_cooled_by_ranges|blks_scanned|blks_days
Object: wafl_cdr_vol
Instance: aggr_aggr2_fp_vol_vol_fp_moveme
Start-time: 3/24/2023 14:56:01
End-time: 3/24/2023 14:56:08
Elapsed-time: 7s
Scope: myCluster-01
Counter                 Value
blks_cooled_by_ranges       -
0 to 2 days              2001
3 to 5 days                 0
6 to 14 days                0
15 to 31 days               0
32 to 45 days               0
>45 days                    0
blks_days                                                       -
000                         0
001                      2001
  • Volume is moved to another Fabricpool aggregate aggr4_fp:
myCluster::*> volume move start -vserver svm1 -volume vol_fp_moveme -destination-aggregate aggr4_fp
[Job 1337] Job is queued: Move "vol_fp_moveme" in Vserver "svm1" to aggregate "aggr4_fp". Use the "volume move show -vserver svm1 -volume vol_fp_moveme" command to view the status of this operation.
svm1 vol_fp_moveme       aggr4_fp           auto                            2
myCluster::*> vol show -vserver svm1 -volume vol_fp_moveme -fields name-ordinal
vserver   volume        name-ordinal
svm1      vol_fp_moveme            1
  • Block temerature is reset, it will take another 2 days minimum before data is tiered:
myCluster::*> statistics show -sample-id mysample -object wafl_cdr_vol -instance aggr_aggr4_fp_vol_vol_fp_moveme(1) -counter blks_cooled_by_ranges|blks_scanned|blks_days
Instance: aggr_aggr4_fp_vol_vol_fp_moveme(1)
Start-time: 3/24/2023 15:12:14
End-time: 3/24/2023 15:12:18
Elapsed-time: 4s
Scope: myCluster-01
Counter                 Value
0 to 2 days                 0
3 to 5 days                 0
6 to 14 days                0
15 to 31 days               0
32 to 45 days               0
>45 days                    0
blks_days                   -
000                         0
001                         0
