NetApp Stage KB
Can't reach management lifs in ifgrp on same network
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9+
  •  Switched management network
Issue
  • Cannot reach node or cluster management IPs even when on the same network
  • Cannot ping in or out
  • Management lifs are in an ifgrp
  •  LACP checks out using
:>ifconfig -v
  • The switches are visible using the command
 ::> network device-discovery show
  • Gateway/default route is set in the same subnet on management network
New to NetApp?
