After performing disk sanitize in maintenance mode node hang when running disk show Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:Visibility:PublicVotes:0Category:ontap-9Specialty:HWLast Updated: Applies to ONTAP 9 Disk santitize Maintenance mode Issue After a disk sanitation is performed in maintenance mode, disk show or disk encrypt show cause node to hang
