NetApp Stage KB
Undertemperature warning observed for temperature sensor 1 on DS2246 shelf
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
HW
Last Updated:
Applies to
DS2246 disk shelf
Issue
  • System is reporting multiple warnings for
Tue Jun 30 09:17:09 GMT [node-01: dsa_worker4: ses.status.temperatureError:critical]: DS2246 shelf 2 on channel 0a temperature error for Temperature sensor 1: critical status; undertemperature failure. Current temperature: 4 C (32 F).
  • Issue can be observed with following command
Cluster::> system node run -node <node name> -command storage show fault
Enclosure Status: non-critical
Channel: 0a
Shelf: 2
Shelf Type: DS2246
Product Serial Number: XXXXXXXXXX
Module Type: IOM6
Temperature Sensors:
Element Status Status Bytes Status Descriptions
1: NONCRITICAL 03,00,18,01 UT WARNING
2: OK 01,00,23,00
3: OK 01,00,27,00
4: OK 01,00,3E,00
5: OK 01,00,26,00
6: OK 01,00,3E,00
7: OK 01,00,28,00
8: OK 01,00,28,00
New to NetApp?
