NetApp Stage KB
PPR memory test passed yet the LED fault light stays ON
5
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
Issue
Node panicked due to an uncorrectable DIMM error:
PANIC: ECC error at DIMM-14: 2C-0F-1651-150A2A63,ADDR 0x7d28fefd80,(Node(0), Memory controller(0), CH(1), DIMM(0), Rank(1), Bank Group(2), Bank(0x0), in process vifmgr on release 9.7P8 (C) on Thu Dec 31 06:50:11 PST 2020 version: 9.7P8:
Verify LED
Note:  For clusters with mixed models it is recommended to run the command for each node individually with the -node parameter.
::> system controller service-event show
Node             ID  Event Location                     Event Description
plata4-1a        1   DIMM in slot 1 on Controller A      Uncorrectable ECC
New to NetApp?
