NetApp Stage KB
P3.3V BATT is critically low (16 mV) and sensor detecting voltage anomalies leading to repeated shutdowns
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
not set
Last Updated:
Applies to
  • FAS8200
  • AFF A300
Issue
  • ONTAP events alerts for coin cell P3.3V BATT. Example:
May 27 13:40:17 [node2:monitor.chassisPower.degraded:ALERT]: Chassis power is degraded: P3.3V BATT is critical low (16 mV).
May 27 14:12:58 [node2:monitor.chassisPower.degraded:ALERT]: Chassis power is degraded: Sensor detecting voltage anomalies.
  • In specific scenarios, the system can experiences a shut down due.
  • The P3V3_BATT sensor voltage value is low.
PVCCP_CPU0       | 1.775      | Volts      | ok         | 0.010     | 0.019     | 2.454     | 2.464
P3V3_BATT        | 0.016      | Volts      | cr         | 0.016     | 0.032     | 4.048     | 4.064
P12V             | 11.842     | Volts      | ok         | 0.000     | 0.000     | 15.810    | 15.810
  • From SP-LATEST-IPMI, AutoSupport section, the P3.3V voltage is repeatedly fluctuating between Low Non-Critical (LNC) and Low Critical (LCR).
==== SP-LATEST-IPMI(node2) ====
tag  origin  fld                                     fault reason                   count  time
1    0x5     /chassis-1/controller-a/coin-1          Voltage Sensor 29 LCR          1      Fri May 31 09:43:38 2024
2    0x5     /chassis-1/controller-a/coin-1          Voltage Sensor 29 LNC          1      Fri May 31 09:43:26 2024
Fault Lights On:
             /chassis-1                                                  2
             /chassis-1/controller-a                          2
             /chassis-1/controller-a/coin-1  2
Sensor Name              State          Current    Critical     Warning     Warning    Critical
            Reading       Low         Low         High High
P3.3V BATT    critlow           16 mV       16 mV       32 mV     4048 mV     4064 mV
  • The issue remains after the coin cell battery replacement.
New to NetApp?
