Node panics and goes down due to card in slot X is not supported
Applies to
- ONTAP 9
- FAS8040
Issue
Node goes down with the below PANIC message:
PANIC : PCI Error NMI from device(s):ErrSrcID(CorrSrc(0),UCorrSrc(0x10)), RPT(0,2,0):PLX PCIE 8724 switch on Controller.PANIC: PCI Error NMI from device(s):ErrSrcID(CorrSrc(0),UCorrSrc(0x10)), RPT(0,2,0):PLX PCIE 8724 switch on Controller. in process idle: cpu3 on release 9.6P10 (C) on Fri Jun 30 00:18:59 IST 2023version: 9.6P10: Thu Aug 20 15:47:05 EDT 2020
