NetApp Stage KB
NS224 shelf connection showing "Write Verification Error: Port e0x Failed"
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • AFF-A400
  • NS224
  • ONTAP 9
Issue
  • Port connecting to NS224 shelf called out for write verification errors:
    [node_01: disk_server_0: callhome.hba.failed:EMERGENCY]: Call home for Write Verification Error: Port e0c Failed. Keep the adapter offline and contact NetApp technical support for assistance.
  • Storage port connected to the NSM100 module flapping:
    [node_01: kernel: netif.linkUp:info]: Ethernet e0c: Link up.
    [node_01: intr: netif.linkUp:info]: Ethernet e0c-30: Link up.
    [node_01: kernel: netif.linkDown:info]: Ethernet e0c: Link down, check cable.
    [node_01: intr: netif.linkDown:info]: Ethernet e0c-30: Link down, check cable.
  • Multiple drives showing timeout errors in EMS logs:
    [node_01: scsi_cmdblk_strthr_admin: scsi.cmd.selectionTimeout:error]: Unknown device e0c.01.0.17L9998: Adapter/target error: HA status 0x7: cdb 0x12. Targeted device did not respond to requested I/O. I/O will be retried.
    [node_01: scsi_cmdblk_strthr_admin: scsi.cmd.selectionTimeout:error]: Unknown device e0c.01.0.16L9998: Adapter/target error: HA status 0x7: cdb 0x12. Targeted device did not respond to requested I/O. I/O will be retried.
    [node_01: scsi_cmdblk_strthr_admin: scsi.cmd.pastTimeToLive:error]: Unknown device ?:?.?: request failed after try #4: cdb 0x12.
    [node_01: scsi_cmdblk_strthr_admin: scsi.cmd.selectionTimeout:error]: Unknown device e0c.01.0.20L9998: Adapter/target error: HA status 0x7: cdb 0x12. Targeted device did not respond to requested I/O. I/O will be retried.
  • System transitions from Multi-Path HA to Single-Path HA configuration and back:
    [node_01: svc_queue_thread: shelf.config.tomixedha:notice]: System has transitioned to a mixture of single, multi-path or quad-path storage configurations.
    [node_01: svc_queue_thread: shelf.config.tompha:info]: System has transitioned to multi-path HA attached storage
  • Shelf module details missing from ENVIRONMENT logs:
    Channel: 0x
        Shelf: 1
        SES device path: local access: 0x.1.2.99
        Module type: NSM100; monitoring is active
        Shelf status: normal condition
    	Boot Device information by element:
    	  [1] Serial number:   Part number:
    	      Type:   Size:
    	      Vendor Id:
    	  [2] Serial number: 201201060020  Part number: ATP SATA III M.2 2280 AF120GSMIC-NT2
    	      Type: SATA SSD  Size: 120GB
    	      Vendor Id:
    	Coin Battery installed element list: 1, 2; with error: none
    	Coin Battery information by element:
    	  [1] Voltage: 0.000
    	  [2] Voltage: 2.962
    	External Ethernet Connector installed element list: 1, 2, 3, 4; with error: none
    	External Ethernet Connector information by element:
    	  [1] MAC address: <N/A>  Attached MAC address: <N/A>
    	      Attached port: <N/A>  Attached chassis: <N/A>
    	      Attached manufacturer: <N/A>
    	      Cable serial number: <N/A>  Cable vendor name: <N/A>
    	      Cable id: QSFP28  Cable end: 1
    	      Cable technology: passive copper  Cable length: 0.5-1.0m
    	  [2] MAC address: <N/A>  Attached MAC address: <N/A>
    	      Cable id: QSFP28  Cable end: 0
    	  [3] MAC address: d0:39:ea:2e:d9:c5  Attached MAC address: d0:39:ea:34:f0:d8
    	      Attached port: e0c  Attached chassis: d0:39:ea:34:f0:da
    	      Attached manufacturer: OS-OTVE-VDI01B
    	      Cable serial number: 93A2117720181  Cable vendor name: Molex
    	  [4] MAC address: d0:39:ea:2e:d9:c6  Attached MAC address: b8:ce:f6:f5:a0:5b
    	      Attached port: e5b  Attached chassis: d0:39:ea:34:ec:c6
    	      Attached manufacturer: OS-OTVE-VDI01A
    	      Cable serial number: 93A2117521151  Cable vendor name: Molex
New to NetApp?
