NetApp Stage KB
Multiple fans have failed and system shuts down on FAS25xx systems
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • FAS25xx systems
Issue
  • System is shutting down minutes after power on
  • EMS
[node-01:monitor.globalStatus.critical:EMERGENCY]: Controller failover of NSH-FAS-01 is not possible: Controller Failover takeover disabled. Disk shelf fault.
[node-01:monitor.fan.critical:EMERGENCY]: 2 fans have failed. Replace them to avoid overheating. If not corrected, system will shutdown in 2 minutes.
[node-01:callhome.fans.failed:EMERGENCY]: Call home for MULTIPLE FAN FAILURE
[node-01:monitor.globalStatus.critical:EMERGENCY]: Controller failover of NSH-FAS-01 is not possible: Controller Failover takeover disabled. Multiple fans has failed. Power Supply Status Critical: PSU1. Disk shelf fault.
  • Physical inspection of PSU FANs show to be standing still
New to NetApp?
