NetApp Stage KB
How to determine AFF A900, ASA A900 or FAS9500 PSU power and efficiency
2
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF A900, ASA A900, AFF A700
  • FAS9500, FAS9000
  • 80 PLUS® Platinum 1600W PSU
  • 80 PLUS® Titanium 2000W PSU
  • This KB article helps you determine the correct part to order when replacing a power supply unit (PSU) in AFF A900, ASA A900, AFF A700, FAS9500 or FAS9000 systems
  • Current 1600-Watt (W) PSUs of NetApp AFF A900, ASA A900, AFF A700, FAS9500 and FAS9000 storage systems are certified at 80 PLUS Platinum efficiency
  • Effective 2024-01-01, Commission Regulation (EU) 2019/424 requires power supplies for certain classes of storage equipment to meet the 80 PLUS Titanium efficiency requirement
  • NetApp 80 PLUS Titanium 2000W PSUs for these models are now available, identified by a blue LED icon label.
  • Currently available PSU options:
Part Number
Part Description
Mfg. Part Number
Vendor + Model
80 PLUS Efficiency
X97600A
Power Supply,1600W
114-00146
Delta DPS-1600AB-4
Platinum
X97603A
Power Supply,2000W Titanium
114-00216
Delta TDPS-2000KB
QCS DCJ20002-12
Titanium
IMPORTANT: Intermixing PSUs with different power ratings and efficiencies in the same chassis is not supported. When replacing a PSU, the correct part must be used or damage to the system might occur.
New to NetApp?
