NetApp Stage KB
HOST PORT FAIL disabled by IOM due to excessive phy reset problems
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • Ontap 9
  • DS460 disk shelf
Issue
  • Host Port fail is being called out in autosupports
  • Messages for phy reset problems and port disables can be seen in event log
    Mon Jan 1 10:39:52 -0500 [NODE-02: dsa_worker5: ds.sas.phyRstProb:debug]: [DCM4-2] on channels 0a shelf ID 11 IOM B bay - reports PHY reset problems.
    Mon Jan 1 10:39:52 -0500 [NODE-02: dsa_worker5: ds.sas.hostphy.disableErr:alert]: Port [DCM4-2] on channels 0a shelf ID 11 IOM B disabled due to excessive phy reset problems.
    Mon Jan 1 10:39:52 -0500 [NODE-02: dsa_worker5: callhome.hostport.disable:alert]: Call home for HOST_PORT_FAIL - Disabled by IOM
  • Storage fault is present with non critical bypassed drawers
Drawers Control Module:Element Status
Status Bytes  Status Descriptions
1 [IOM12 A]    : OK                01,00,01,00   REPORT
2 [IOM12 A]    : OK                01,00,01,00   REPORT
3 [IOM12 A]    : OK                01,00,01,00   REPORT
4 [IOM12 A]    : OK                03,00,01,00   REPORT
5 [IOM12 A]    : OK                01,00,01,00   REPORT
6 [IOM12 B]    : OK                01,00,01,00   REPORT
7 [IOM12 B]    : OK                01,00,01,00   REPORT
8 [IOM12 B]    : OK                01,00,01,00   REPORT
9 [IOM12 B]    : NONCRITICAL       03,00,11,00   REPORT, PATH FAIL
10 [IOM12 B]   : OK                01,00,01,00   REPORT
New to NetApp?
