NetApp Stage KB
Fault LED is lit for no apparent reason on a FAS or AFF HA storage system with internal-only SAS storage
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • Platforms:
    • AFF A220, AFF A200, AFF A150, AFF C190, ASA A150
    • FAS2820, FAS2750, FAS2720, FAS2650, FAS2620, FAS2554, FAS2552, FAS2520
  • High-availability configuration (2 processor control modules (PCM) are inserted in the chassis and are configured for HA operation)
  • Internal SAS storage only (no external SAS storage shelves are attached)
  • 0a or 0b SAS ports on the PCMs are directly connected to the SAS ports on the other PCM
Issue
Active IQ will report the following error:
Incorrect SAS cross-connect cabling between SAS ports 0a and 0b on PCM A and PCM B has been detected.
This article applies if any of the following symptoms are observed.
  1. EMS event: When port 0b on PCM A is connected directly to port 0b on PCM B, you will occasionally see this EMS event in the event log: config.invalid.PortToPort
Example:
Fri Dec 09 14:30:00 PST [node1: pmcsas_intrd_0: config.invalid.PortToPort:error]: SAS adapter "0b" is attached to another SAS adapter.
  1. Environment: Run the environment shelf nodeshell command from one of the nodes. The listed SAS cable serial number on the internal shelf's [2] and [4] SAS expander ports are identical. Expander port [2]  is the 0a port on PCM A and port [4] is the 0a port on PCM B.
      SAS cable information by element:
      [1] Internal connector
      [2] Vendor: Amphenol
      Type: QSFP passive copper 0.5-1.0m  ID: 01 Swaps: 0
      Serial number: APF14131767EE1  Part number: 112-00176+A0
      [3] Internal connector
      [4] Vendor: Amphenol
      Type: QSFP passive copper 0.5-1.0m  ID: 00 Swaps: 0
  1. sysconfig -a: Run the sysconfig -a nodeshell command from both nodes. The following conditions are observed:
  • System Storage Configuration: Single-Path HA
  • The SAS 0b ports on both nodes show the identical QSFP serial number.
PCM A:
                slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <UP>)
                                Firmware rev:       01.11.06.00
                                Base WWN:           5:00a098:00361ff:74
                                Phy State:          [4] Enabled, 6.0 Gb/s
                                                    [5] Enabled, 6.0 Gb/s
                                                    [6] Enabled, 6.0 Gb/s
                                                    [7] Enabled, 6.0 Gb/s
                                QSFP Vendor:        Amphenol
                                QSFP Part Number:   112-00176+A0
                                QSFP Type:          Passive Copper 0.5m ID:01
                                QSFP Serial Number: APF14131767EDC
PCM B:
                                Base WWN:           5:00a098:0035e3d:b4
                                QSFP Type:          Passive Copper 0.5m ID:00
  1. SAS-Expander-Map: Run the sasstat expander_map nodeshell command from one of the nodes. The output contains only one entry on channel 0a.
Expanders on channel 0a:
Level  1: WWN 500a098003xxxxxx, ID  0, Serial Number ' SHFFG1416xxxxxx', Product 'DS212IOM6E      ', Rev '0142', Slot A
Expanders on channel 0b:
New to NetApp?
