Enclosure Status is critical with error "Power control state: critical - power control fault detected"
Applies to
- DS14mk4 FC
- Data ONTAP 8
- SCSI Enclosure Services (SES)
Issue
- Enclosure status and Power Ctrl are critical in command "
storage show fault".
Example:
Enclosure Status: critical
Channel: 12b
Shelf: 1
Shelf Type: DS14-Mk4-FC
Product Serial Number: OPS67734221717E
Module Type: ESH
Vendor Unique Element 80-ESH: (ESH HUB)
Element Status Status Bytes Status Descriptions
1 [ESH A] : OK 01,00,00,03
2 [ESH A] : OK 01,00,00,03
Vendor Unique Element 84-ESH: (Power Ctrl)
1: CRITICAL 02,86,00,00
- Power control state is "
critical - power control fault detected" in command "environment status"
Example:
Channel: 12b Shelf: 1 Shelf Serial Number: OPS67734221717E
Shelf product id: DS14-Mk4-FC
Module A Serial Number: IMS6981331F5A74 Firmware rev: 14
Module B Serial Number: IMS6981331F5C7B Firmware rev: 14
Controller A boot time: 2738 days 4 hrs 5 mins 11 secs
Controller B boot time: 2741 days 19 hrs 43 mins 31 secs
Last power control completion status: inconsistent drive status
Timestamp: Sun Jun 28 14:20:44 CST 2020
