NetApp Stage KB
Embeded shelf id shows unknown code 00xxAxxx after MB replacement with no storage fault
1
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • FAS2750
  • ONTAP 9
Issue
  • After partner's MB replacement, local node shows internal shelf id changed from 00 to an unknown code 00xxAxxx, sequence of all bay numbers have also changed.:
System Storage Configuration: Multi-Path HA
 slot 0: SAS Host Adapter 0a (PMC-Sierra PM8070 rev. C, SAS, <UP>)
  Temperature:        Not Available
  Phy State:          [0] Enabled, 12.0 Gb/s
                      [1] Enabled, 12.0 Gb/s
                      [2] Enabled, 12.0 Gb/s
                      [3] Enabled, 12.0 Gb/s
  Mini-SAS HD Vendor:        Amphenol
  Mini-SAS HD Part Number:   112-00435+A0
  Mini-SAS HD Type:          Passive Copper (unequalized) 0.5m ID:01
  Mini-SAS HD Serial Number: APFxxxxxxx
  00xAxxBx.1: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.3: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.5: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.7: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.9: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.11: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.13: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.15: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.17: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.19: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.21: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.23: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.0: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.2: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.4: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.6: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.8: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.10: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.12: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.14: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.16: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.18: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.20: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  00xAxxBx.22: NETAPP   X343_TA15E1T8A10 NA01 1713.5GB 520B/sect (xxxxxxxxxx)
  Shelf 0: DS224-12  Firmware rev. IOM12E A: 0250  IOM12E B: 0250
  • SAS-EXPANDER-MAP shows shelf serial number changed to the code.
Expanders on channel 0a:
Level    1: WWN 500ayyyyyyyyyy, ID 127, Serial Number '        0038A542', Product 'DS22412IOM12E   ', Rev '0250', Slot A
Expanders on channel 0b:
Level    1: WWN 500ayyyyyyyyyy, ID  0, Serial Number ' SHFNCxxxxxxxxxxx', Product 'DS22412IOM12E   ', Rev '0250', Slot A
  • No storafe fault found.
No faults found in storage subsystem
New to NetApp?
