NetApp Stage KB
Controller Chassis Amber LED ON after reinstall ONTAP 9.8 from 8.2.5 7-mode
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
FAS2552
Issue
  • Two controller amber LED and chassis amber LED ON after reinstall ONTAP 9.8 from 8.2.5 7-mode.
  • Enclosure status is critical in storage show fault -v
Channel: 0a
Shelf: 0
Shelf Type: DS2246
Product Serial Number: SHFFG1515000211
Module Type: IOM6E
Enclosure:
Element Status Status Bytes Status Descriptions
1: OK 01,00,02,00 FAIL
Vendor Unique Element 85-IOM6E: (ACP)
1 [IOM6E A] : CRITICAL 02,10,00,40 INBACP, FAIL
2 [IOM6E B] : CRITICAL 02,10,00,40 INBACP, FAIL
Vendor Unique Element 88-IOM6E: (PCM)
1: OK 01,01,00,80 PC SHELF FAULT RQSTD
2: OK 01,01,00,80 PC SHELF FAULT RQSTD
New to NetApp?
