Call home for BATTERY (not present) CRITICAL on AFF A220
Applies to
- AFF A220
- Baseboard Management Controller(BMC) 11.11
- The issue persists after reseating NVMEM Battery
Issue
- The node is down and the following error is reported in
system log.
[Node-01:nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (30 ). To prevent data loss, the system will shut down in 20 minutes.[Node-01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.[Node-01:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery PCT capacity critical)Waiting for PIDS: /usr/sbin/rpcbind 1042.Terminated.Uptime: 136d15h0m58sFM halt: Time 11804338635 ms, 17665793024310860 cyclesSystem powering down...- The following errors report on boot up.
WARNING: The battery is experiencing a critical failure:- Failed to charge the batteryWithout a working battery, the system cannot retain dataduring a power outage, which can result in data loss.Power down the system and verify that the battery isproperly installed.To ignore this failure and boot the system in a modewhere data loss might occur, press 'c' followed by 'Enter'[Node-01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.[Node-01:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.- The following error occurs when running
system battery showfrom BMC.
BMC Node-01> system battery showBattery pack is absent.- Battery sensors show
nainbmc status -d.
ipmi_sensors============Sensor Name | Current | Unit | Status | LCR | LNC | UNC | UCR-----------------+------------+------------+------------+-----------+-----------+-----------+-----------Bat_Temp | na | degrees C | na | 0.000 | 5.000 | 56.000 | 60.000Bat_Volt | na | Volts | na | 5.500 | 5.600 | 8.500 | 8.600Bat_Curr | na | Amps | na | na | na | 1.520 | 1.800Bat_Rem_Cap | na | Amps * hour | na | na | na | na | naBat_Full_Cap | na | Amps * hour | na | na | na | na | naBat_Charge_Curr | na | Amps | na | na | na | 2.400 | 2.900Bat_Charge_Volt | na | Volts | na | na | na | 8.900 | 9.000Bat_Design_Cap | na | Amps * hour | na | na | na | na | naBat_Initial_Fcc | na | Amps * hour | na | na | na | na | naBat_Average_Temp | na | degrees C | na | na | na | na | naBat_Rem_Cap_off | na | Amps * hour | na | na | na | na | naBat_Dstg_Cycles | na | cycles | na | 2.000 | 5.000 | na | naBat_Power_Fault | 0x0 | discrete | Asserted | na | na | na | naBat_Dsg_FET_Flt | na | discrete | na | na | na | na | naBat_Chg_FET_Flt | na | discrete | na | na | na | na | naBat_Pack_Invalid | na | discrete | na | na | na | na | naBat_Cycle_Cnt | na | cycles | na | na | na | na | naBat_Lrn_Active | na | discrete | na | na | na | na | na
