NetApp Stage KB
Battery sensors failed and an IPMI emergency triggered on the FAS2650
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • FAS2650
  • ONTAP 9
Issue
  • During the battery learning cycle, the system shut down because of the IPMI sensors detected several battery errors.
Record 615: Mon Sep  2 12:00:13 2024 [IPMI.notice]: 5a01 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
Record 616: Mon Sep  2 17:48:07 2024 [IPMI.emergency]: triggered OS halt: Battery PCT capacity critical
Record 617: Mon Sep  2 17:48:22 2024 [IPMI.notice]: 5b01 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 618: Mon Sep  2 17:48:41 2024 [IPMI.notice]: 5c01 | 02 | EVT: 6f406fff | Sensor 255 | Assertion Event, "Storage OS stop/shutdown"
Record 619: Mon Sep  2 17:48:40 2024 [ONTAP.notice]: Appliance user command halt.
Record 620: Mon Sep  2 17:48:41 2024 [IPMI Event.critical]: System power down
Record 621: Mon Sep  2 17:48:41 2024 [IPMI.emergency]: Shutdown by Data ONTAP
Record 622: Mon Sep  2 17:48:41 2024 [Trap Event.critical]: hwassist abnormal_reboot (28)
Record 623: Mon Sep  2 17:48:44 2024 [IPMI.notice]: 5d01 | 02 | EVT: 0300ffff | Power_Good | Assertion Event, "State Deasserted"
Record 624: Mon Sep  2 17:49:01 2024 [ASUP.notice]: First notification email | (REBOOT (abnormal)) WARNING | Sent
Record 625: Mon Sep  2 17:59:55 2024 [SP.critical]: Heartbeat stopped
Record 626: Mon Sep  2 18:03:45 2024 [ASUP.notice]: Reminder email | (REBOOT (abnormal)) WARNING | Sent
Record 627: Mon Sep  2 20:10:09 2024 [IPMI.emergency]: triggered OS halt: Battery temp critical
Record 628: Mon Sep  2 22:23:10 2024 [IPMI.emergency]: triggered OS halt: Battery voltage critical
Record 629: Tue Sep  3 00:36:51 2024 [IPMI.emergency]: triggered OS halt: Battery current critical
  • According to the environment sensors,
    • the Bat Learning Active status is still ON, and many statuses have failed
    • The Bat Pct Capacity is critlow
    • The battery charge has failed, and the Dblade Temp is OVER_TEMP.
Bat Present                             PRESENT
Bat Temp                 failed            -- C         0 C         5 C        60 C        75 C
Bat Volt                 failed            -- mV     5500 mV     5600 mV     8500 mV     8600 mV
Bat Pct Capacity         critlow           30 %        39 %        44 %        --          --
Bat Curr                 failed            -- mA       --          --        1200 mA     1520 mA
Bat Rem Cap              normal           512 mA*hr    --          --          --          --
Bat Full Cap             normal           512 mA*hr    --          --          --          --
Bat Charge Curr          normal             0 mA       --          --        2200 mA     2300 mA
Bat Charging State       failed             --
Bat Charge Volt          normal          8200 mV       --          --        8900 mV     9000 mV
Bat Initial FCC          normal          1700 mA*hr    --          --          --          --
Bat Dstg Cycles          normal            10 cycles    2 cycles    5 cycles   --          --
Bat Power Fault                           GOOD
Bat Dcharge FET                             ON
Bat Charge FET                              ON
Bat Cycle Count          normal            35 cycles   --          --          --          --
Bat Learning Active                         ON
Bat Pack Invalid                            OK
Wrench Port Up                              UP
Attention                               ASSERT
NV0 Battery State                       FULLY_DISCHARGED
NV0 Battery Voltage      failed            -- mV     5500 mV     5600 mV     8500 mV     8600 mV
NV0 Type                                TYPE_NVMEM
Mgmt Port Count          normal             1          --          --          --          --
Bat Count                normal             1          --          --          --          --
Thermal Zone Count       normal             1          --          --          --          --
Fan Count                normal             4          --          --          --          --
PSU Count                normal             2          --          --          --          --
Mgmt Port Link           normal             0          --          --          --          --
Battery Charge           failed             --
Dblade Battery Status                   FULLY_DISCHARGED
Dblade Temp                             OVER_TEMP
init                     invalid            --
  • Replacing NVMEM battery doesn't fix the issue.
New to NetApp?
