NetApp Stage KB
ANDU paused: node not in 'waiting for giveback' state due to BIOS firmware upgrade failure
2
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • AFF A300
  • Automated Non-Disruptive Upgrade (ANDU)
Issue
Automated Non-Disruptive Upgrade (ANDU) is paused because the partner is not in a "waiting for giveback"
  • In EMS
[node-01: upgrademgr: upgrademgr.update.pausederr:ERROR]: The automated update of the cluster has been paused due to the following reason: Node "node-01": Error: {Node "node-02" is not in "waiting for giveback" state.}, Action: {Use the "storage failover show" to verify that node "node-02" is in one of the following states: "waiting for giveback" or "connected".}.
[node-01: notifyd: callhome.andu.pausederr:alert]: params: {'epoch': '91e735df-158b-4999-8546-5523299458af', 'subject': 'AUTOMATED NDU PAUSED'}
  • cluster image show-update-progress
::> cluster image show-update-progress
                                             Estimated         Elapsed
Update Phase         Status                   Duration        Duration
Pre-update checks    completed                00:10:00        00:00:35
Data ONTAP updates   paused-on-error          01:23:00        00:37:18
Details:
Node name            Status            Status Description
node-01         waiting
node-02         failed            Error: Node "node-02" is not in
                                       Action: Use the "storage failover
Saving Primary Image to Backup flash device
fail unlocking memory
Failed. -4 bytes written: I/O error
Failed to save Primary Image to Backup flash device.  Programming of Primary aborted
Automatic firmware update skipped (update_flash command failed).
Warning: The boot media contains a newer firmware image (11.21).
Please run 'update_flash' at the Loader prompt to update your
system firmware (11.20).
New to NetApp?
