NetApp Stage KB
AFF A700s CECC: Correctable Machine Check Errors being reported against wrong DIMM
1
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • AFF A700s
  • ONTAP 9
    • ONTAP 9.1P17 and earlier
    • ONTAP 9.3P11 and earlier
    • ONTAP 9.4P6 and earlier
Issue
The CECC error is reported in the same DIMM even after a replacement:
  • The system health alert show command reports errors similar to the following on the cluster:
Node                  xxxxxx
Monitor               controller
Alert ID              CriticalCECCCountMemErrAlert
Alerting Resource     DIMM-x
Subsystem             Memory
Indication Time       Tue Oct 09 12:24:36 2018
Perceived Severity    Critical
Probable Cause        DIMM_Degraded
Description           The DIMM has degraded, leading to memory errors.
  • The EMS log displays a message similar to the following, reporting CECC error on the specific DIMM:
[?] Tue Oct 09 12:24:36 IST [xxxx: mgwd: callhome.hm.alert.critical:alert]: Call home for Health Monitor process nphm: CriticalCECCCountMemErrAlert[DIMM-x].
  • Normally, a replacement of this DIMM is suggested.
  • However, even after the replacement, the errors in the same DIMM might be reported by the cluster.
New to NetApp?
