NetApp Stage KB
SAML authentication not working for ONTAP System Manager due to an incorrect IdP URL
2
Visibility:
Votes:
0
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP System Manager (OSM)
  • SAML Authentication via AD
  • Cloud Volumes ONTAP (CVO)
Issue
  • Previously working SAML configuration is disabled.
    • ::> security saml-sp show
      (security saml-sp show)
      This table is currently empty.
    • ::> security saml-sp status show
      Node SAML SP Status Enabled
      Node1 config-success true
      Node2 config-success true
      Node3 config-success true
      Node4 config-success true
      Node5 config-success true
      Node6 config-success true
      6 entries were displayed.
  • While trying to disable saml-sp gives below error:
::> security saml-sp modify -is-enabled false
Error: command failed: SAML authentication can only be disabled from the "console" application or from a SAML authenticated application.
New to NetApp?
