NetApp Stage KB
StorageGRID appliance reporting Isolation of Drive causing redundancy mismatch MEL event on storage controller E2800 after drive replacement
1
Visibility:
Votes:
0
Category:
e-series-santricity-os-controller-software
Specialty:
esg
Last Updated:
Applies to
  • StorageGRID appliance SG6060
  • E-Series controller E2800 of StorageGRID appliance
Issue
  • AutoSupport case automatically created for (Isolation of drive causing redundancy mismatch) CRITICAL
  • E-Series MEL events shows the Impending Drive Failure triggered a drive copy to the preservation capacity earlier.
B:5/22/23, 7:48:36 PM (19:48:36) 5208 3803 Disk pool reconstruction reserved drive count is below threshold - Disk Pool StorageGRID-disk-pool99 <--CRITICAL
B:5/22/23, 7:48:36 PM (19:48:36) 5207 227e Drive copy started - Shelf 99, Drawer 4, Bay 5
A:5/22/23, 7:48:36 PM (19:48:36) 5206 3803 Disk pool reconstruction reserved drive count is below threshold - Disk Pool StorageGRID-disk-pool99 <--CRITICAL
B:5/22/23, 7:48:34 PM (19:48:34) 5205 1023 Drive copy triggered by a controller detected impending drive failure - Shelf 99, Drawer 4, Bay 5 - WWN: 5000ccaxxxxxx
  • Later the drive was Failed and replaced, which then the bad data copied back to the new disk triggering isolation event.
A:5/25/23, 12:05:35 AM (00:05:35) 5287 2046 Isolation of drive causing redundancy mismatch - Shelf 99, Drawer 4, Bay 5 - LBA: 0x1f440dc00 - SSID: 0x12 = 18 <--CRITICAL
A:5/25/23, 12:05:35 AM (00:05:35) 5286 2035 Redundancy not consistent - Volume StorageGRID-obj-14 - SSID: 0x12 = 18 - LBA: 0x00000000, Blocks:32768
A:5/24/23, 2:02:24 PM (14:02:24) 5282 380a Disk pool reconfiguration started - Disk Pool StorageGRID-disk-pool99
A:5/24/23, 2:02:17 PM (14:02:17) 5281 2401 Hot swap monitor detected drive insertion - Shelf 99, Drawer 4, Bay 5 - WWN: 5000cca0c8245314
A:5/24/23, 2:01:50 PM (14:01:50) 5280 2858 Drawer closed - Shelf 99, Drawer 4
B:5/24/23, 2:02:27 PM (14:02:27) 5279 380a Disk pool reconfiguration started - Disk Pool StorageGRID-disk-pool99
B:5/24/23, 2:02:20 PM (14:02:20) 5278 2263 The drive replacement succeeded - Shelf 99, Drawer 4, Bay 5
B:5/24/23, 2:02:20 PM (14:02:20) 5277 2228 Drive deleted - Shelf 99, Drawer 4, Bay 5
B:5/24/23, 2:02:14 PM (14:02:14) 5276 2401 Hot swap monitor detected drive insertion - Shelf 99, Drawer 4, Bay 5 - WWN: 5000ccaxxxxxx
B:5/24/23, 2:01:47 PM (14:01:47) 5275 2858 Drawer closed - Shelf 99, Drawer 4
B:5/24/23, 2:01:39 PM (14:01:39) 5274 101f Summary of impending drive failure detected by controller - Shelf 99, Drawer 4, Bay 5 - Detected by: 0, Sense Key: 0
----> Current/Cumulative Recovered Errors: 0/10, Medium Errors: 0/0, Hardware Errors: 0/0, Stagnant IO: 0/0
New to NetApp?
