NetApp Stage KB
Loss of Host-side connection redundancy detected on iSCSI host interface card after controller replacement
3
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E5700/ EF570 and E2800/ EF280 having 25GB iSCSI HIC with E-series controller OS 11.60.2 or newer
  • Host interface cards (HIC)
  • AutoCode Sync (ACS)
  • Replacement controller has 11.60.1 or older firmware.
Issue
  • Autosupport triggered below alerts on iSCSI HIC after both controllers replaced
E-Series Notification (Loss of host-side connection redundancy detected) CRITICAL
E-Series Notification (Host multipath driver configuration error detected) CRITICAL
  • Storage Array Profile shows MAC addresses used by the controllers having only two unique MAC addresses for all eight ports.
Example as below:
Controller in Shelf 99, Bay A
      Host interface:                                       iSCSI
         Host Interface Card(HIC):                          1
         Channel:                                           5
         Port:                                              0e
         Link status:                                       Connected
         MAC address:                                       be:ef:de:ad:be:ef
This behavior was not observed prior to replacement of controllers:
         Channel:                                           5
         Port:                                              0e
         MAC address:                                       00:a0:98:d5:44:c8
New to NetApp?
