How to patch Java JRE versions for older SANtricity Management Plug-ins and APIs
Applies to
- SANtricity
- NetApp - Patch for Updating Java Runtime Environment (JRE) used by the applications Web server.
- NetApp SANtricity Plug-in for VMware vCenter
- NetApp SANtricity Management Pack for Microsoft System Center Operations Manager
- NetApp SANtricity Web Services Proxy
- NetApp SANtricity Storage Replication Adapter
- NetApp SANtricity VASA Provider
- NetApp E-Series Plug-In for VMware vCenter 2.7
- NetApp SCOM Integration Pack 2.1
- NetApp SANtricity Web Services Proxy 1.1
- NetApp Storage Replication Adapter for E-Series 5.5
- NetApp VASA Provider for E-Series 5.5
This article describes the procedure on how to patch Java JRE versions for older SANtricity Management Plug-ins and APIs.
This script allows the user to change the JRE version used to run the Web server from the pre-installed version to a more recent one.
SANtricity Management Plug-ins - 1.0J
New JREs can be downloaded from Oracle at the following link and installed as documented.
Java SE Downloads
