SANtricity Enterprise Management Window and Array Management Window versions do not match
Applies to
- E-Series Controller Firmware 7.xx
- E-Series Controller Firmware 8.xx
- E-Series SANtricity Management Software
Issue
Scenario 1:
The version of Storage Manager Enterprise Management mismatches with Array Management. In below sample, the version of Enterprise Management is 11.30:
While Array Management is 11.25:
Scenario 2:
Below error may be seen during Controller Firmware, when a specific firmware file, which is shown only when "All Firmware Files" or "All Files" instead of "Compatible Firmware Files" is selected in "Select File" window, is selected:
RC_nnnnnnnn_xxxx.dlp is not compatible with this version of the storage management software.
Scenario 3:
Error may be encountered when accessing a storage array from SANtricity Storage Manager:
The storage management software (version xx.yy.zzzz.nnnn) you are attempting to use is not compatible with the firmware on the controllers in Storage Array <array_name>.
