NetApp Stage KB
E-Series SANtricity mapping not possible for Default Cluster via Web GUI
1
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
Netapp SANtricity OS 11.60.2R1
Issue
Unable to Assign Volume due to error message which advises Data Assurance be disabled before assigning Volume.
Disable Data Assurance to Assign Volume
The default cluster has at least one host port that is connected to the storage array through an I/O interface that is NOT data assurance (DA) capable. However, The following volumes have data assurance (DA) enabled. If you want to assign these volumes to default cluster, the DA capability must be disabled on the Volumes.
Important: disabling data Assurance Protection is an irreversible action. Once disabled, you cannot re-enable it.
New to NetApp?
