NetApp Stage KB
How is the block size for disk drive (SSD/SAS) and volume?
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E-Series (EF300/EF600/E2800)
  • SANtricity 11.70 or later
Answer
Disk Drive
  • SAS drive: The size can be either 512 bytes or 4KB, depending on the disk model
Example (Storage Array Profile log):
     Media type:                     Hard Disk Drive
      Interface type:                 SAS
      Speed:                          10,500 RPM
      Current data rate:              12 Gbps
      Logical sector size:            512 bytes
      Physical sector size:           512 bytes
      Product ID:                     ST1200MM0009
      Drive Firmware:                 MS02
      Serial number:                  WFK88RB90000K101ALHL
      Manufacturer:                   SEAGATE
      Date of manufacture:            July 21, 2020
      Interface type:                 SAS
      Speed:                          10,500 RPM
      Physical sector size:           4096 bytes
      Product ID:                     ST1800MM0129
      Drive Firmware:                 NE03
  • Solid State Disk (SSD)
    • SAS-type: 4KB
    • NVMe-type: 4KB
Example:
Drive media type:              Solid State Disk
Drive interface type:          NVMe
Physical block size:           4,096 bytes
Shelf loss protection:         No
   Media type:                     Solid State Disk
      Interface type:                 SAS
      Drive path redundancy:          OK
Volume
  • By default:
    • EF300 and EF600 with FC-type is 4K
    • EF300 and EF600 with iSCSI-type is 512 bytes
    • E2800 is 512 bytes
  • Both 512 bytes and 4KB are supported and configurable by CLI
  • Only EF300 and EF600 with FC-model can use GUI feature to configure Volume Block Size while creating volume.
Additional Information
additionalInformation_text
