E-Series replacement controller boots into OE LU state when expansion enclosure contain IOM12B modules
Applies to
- NetApp E-Series
- Controller Replacement
- NetApp E-Series DE460C expansion shelf with IOM12B modules (Note the blue stripe vertically across the modules).
Issue
- After performing a controller replacement, the replacement goes into lock down state with the display code being
OE LU. - The controller console output or (
excLogShowcommand) indicate the following assertion is hit by the controller:
ASSERT: Assertion failed: slotNum < numSlots, file ionLogicalUnit.cc, line 5240
