Blinking fault led light indicator with no errors reported on E-Series array Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:1Visibility:PublicVotes:0Category:e-series-disk-shelvesSpecialty:esgLast Updated: Applies to E-Series E2860 SANtricity OS 11.80.1R3 Issue Blinking blue led light indicator light frequently on the E-Series Shelf/ chassis with no errors reported:
