Primary Admin node shows all nodes unknown while Secondary Admin node shows PA node in an unknown state Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:Visibility:PublicVotes:0Category:storagegridSpecialty:sgridLast Updated: Applies to StorageGRID Issue When logging into PA(Primary Admin) node, services fails to start and all nodes in an unknown state
