NetApp Knowledge Base site will be down for 3 hours between Oct 26, 23:59 PST and Oct 27, 02:59 PST, for system maintenance and infrastructure update.
NetApp Stage KB
cannot add a Plug-In Host to SC
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Server (SC) 4.2.1
  • SnapCenter Server (SC) 4.4
  • User Access Control (UAC)
  • Windows Server 2012 R2
  • User account being used is a local user of the Host, member of the Administrators group but user is not called Administrator
Issue
SC UI fails to add a Plug-In Host and reports the following error message:
The host  is not accessible with the specified credentials. You must ensure that the following conditions are met:
  • The credential has administrator privileges for the plug-in host.Elevated privileges are required for local user accounts.
  • The required ports are open between SnapCenter Server and the plug-in host if the firewall is enabled. For more information on ports, see SnapCenter Installation and Setup Guide.
New to NetApp?
