NetApp Knowledge Base site will be down for 3 hours between Oct 26, 23:59 PST and Oct 27, 02:59 PST, for system maintenance and infrastructure update.
NetApp Stage KB
SnapCenter SQL Backup Failed in an always on cluster configuration
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for SQL (SCSQL)
  • SQL Master DB backups inside same job as user DB
  • Issue
After a SQL Server failover the following message is seen inside the jobs in the SnapCenter GUI:
Activity 'Get Backup Metadata' failed with error: Object reference not set to an instance of an object.
Activity 'Begin Transaction Log backup' failed with error: The operation has timed out
When moving the owner back to the previous node the error is not seen any more
New to NetApp?
