NetApp Knowledge Base site will be down for 3 hours between Oct 26, 23:59 PST and Oct 27, 02:59 PST, for system maintenance and infrastructure update.
NetApp Stage KB
Can SnapCenter manage SVM-DR relationships?
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter 4.x
  • SVM-DR
Answer
  • SVM-DR is not supported with SnapCenter (see ONTAP features not supported)
  • The following error may be seen:
Because the parent volume is unprotected in the Vserver DR relationship. If volume requires Vserver DR protection, protect the parent volume first using the "volume modify -vserver-dr-protection protected" command. Otherwise, to create a clone without protection, specify the "-vserver-dr-protection unprotected" parameter
Additional Information
N/A
