NetApp Knowledge Base site will be down for 3 hours between Oct 26, 23:59 PST and Oct 27, 02:59 PST, for system maintenance and infrastructure update.
NetApp Stage KB
CVE-2021-44228 vulnerability is reported on SnapCenter Server
69
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Server
Issue
A security scan reports a critical vulnerability on the SnapCenter Server (Windows)
Plugin id:
	156002
Plugin Name:
	Apache Log4j < 2.15.0 Remote Code Execution
Severity:
	critical
Plugin Text:
	"<plugin_output>
	  Path              : C:\Program Files\NetApp\SnapCenter\SnapCenter Plugin for VMware\lib\log4j-1.2.17.jar
	  Installed version : 1.2.17
	  Fixed version     : 2.15.0
	</plugin_output>"
Description:
	"The version of Apache Log4j on the remote host is < 2.15.0. It is, therefore, affected by a remote code execution vulnerability in the JDNI parser due to improper log validation.
	An unauthenticated, remote attacker can exploit this to bypass authentication and execute arbitrary commands.
	Note that Nessus has not tested for these issues but has instead relied only on the application's self-reported version number."
Solution:
	Upgrade to Apache Log4j version 2.15.0 or later, or apply the vendor mitigation.
CVE:
	CVE-2021-44228
CVSSv3 Score:
	10
New to NetApp?
