Backup unable to create snapshots after upgrade
Applies to
- SnapCenter Server (SC) 4.5
- SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 4.5
Issue
- SCSQL backup fails to create snapshots on the storage
- See the following errors in the
<installation_path>\Program Files\NetApp\SnapCenter\SMCore\log\SMCore_<id>.log
and<installation_path>\Program Files\NetApp\SnapCenter\SMCore\SnapDriveSALDebug.log
respectively:
DEBUG SMCore_2333797 PID=[6584] TID=[41] Create Snapshot - Begin
DEBUG SMCore_2333797 PID=[6584] TID=[41] Create Snapshot - End
ERROR SMCore_2333797 PID=[6584] TID=[41] Create snapshot '<snapshot_name>' failed: Snapshot operation failed. Value cannot be null.
Error SDW PID=[5468] TID=[15532] Failed to run a command Get-NcVol at SnapDrive.Nsf.Common.PowerShell.PSHelper.RunCommand[T](Command
command, IEnumerable input, Boolean isRetryAllowed)
Error SDW PID=[5468] TID=[15532] Failed to get the volumes for all volumes.
