NetApp Stage KB
SnapCenter upgrade failure - SnapCenter Schema Creation
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Server 6.0, 6.0.1
  • ASP .NET Core Runtime Hosting Bundle
Issue
  • SnapCenter upgrade fails with error:
ERROR: SnapCenter Schema Creation failed.  Check the DotMigrate logs in the Windows Temp folder for more details.snapcenter schema creation failed.png
  • The corresponding DotMigrate logs referenced in the error (SC_DotMigrate_*) are not present in the Windows Temp folder.
  • The Windows Application Event Viewer log shows an error, "A .NET application failed", (Event ID 1023):
Log: Application
Entry Type: Error
Time Generated: 5/6/2024 3:08:44 AM
Source: .NET Runtime
Message: Description: A .NET application failed.
Application: dotMigrate.exe
Path: C:\Users\administrator.DEMO\AppData\Local\Temp\ruc3ep43.3m5\dotMigrate.exe
Message: You must install or update .NET to run this application.
The 'SMS_Upgrade_<date_time>.log' throws an error regarding the dotMigrate upgrade failing:
CreateDB: CustomAction1: Call dotMigrate C:\Users\<user_account>\AppData\Local\Temp\ruc3ep43.3m5\dotMigrate.exe
CreateDB: CustomAction1: With commandline  -i -v -r -s "C:\Users\<user_account>\AppData\Local\Temp\ruc3ep43.3m5\2.0" -h localhost -y 3306 -l C:\Users\<user_account>\AppData\Local\Temp\SC_DotMigrate_MySQL_v2.0_<date_time>.log -d nsm -x MySqlConnector
CreateDB: CustomAction1: dotMigrate Exitcode  -2147450730
CreateDB: CustomAction1: Error!!!! dotMigrate return with failure
New to NetApp?
