NetApp Stage KB
SnapCenter open-smconnection fails to initialize a connection
2
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter
Issue
You may encounter and error similar to the following.  The connection immediately fails and there are no logs generated in SnapCenter that reveal the isssue
PS C:\WINDOWS\system32> Open-smconnection -SMSbaseurl https://snapcenter.server.com:8146
cmdlet Open-SmConnection at command pipeline position 1
Supply values for the following parameters:
(Type !? for Help.)
Credential
Open-smconnection : The underlying connection was closed: An unexpected error occurred on a send.Unable to read data
from the transport connection: An existing connection was forcibly closed by the remote host.
At line:1 char:1
+ Open-smconnection -SMSbaseurl https://snapcenter.server.com:8146
    + CategoryInfo          : OpenError: (SmPSSnapin.PSAddSmSession:PSAddSmSession) [Open-SmConnection], Exception
    + FullyQualifiedErrorId : Operation failed,SmPSSnapin.PSAddSmSession
New to NetApp?
