NetApp Stage KB
SnapCenter is unable to discover resources when using disjoint namespace
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter 4.9
Issue
  • SnapCenter is unable to discover resources when using disjoint namespace
  • When adding a host or cluster, SCW discovery does not work and the file system is not discovered
    •  Standalone host
      • Response error: Host 'hostname' is not registered with SnapCenter Server
    • Cluster
      • Failed to find host (hostname). Verify the host is up and running and check the DNS and firewall settings. No such host is known
Note: If these errors are seen when using disjoint namespaces, follow the Solution section
New to NetApp?
