NetApp Stage KB
SnapCenter installation failed with error "cannot be loaded because running scripts is disabled on this system"
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter 4.x
Issue
  • While installing the SnapCenter server found out that the Windows setting prevents the running of PowerShell scripts that are needed to complete the installation successfully.
  • Below error Message seen in Installation logs:
Get_Adapters.ps1 cannot be loaded because running scripts is disabled on this system.
Running the same script via PowerShell will show the below error:
New to NetApp?
