SnapCenter Server Not Connecting to Storage After SVM Rename Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:1Visibility:PublicVotes:0Category:snapcenterSpecialty:SNAPXLast Updated: Applies to SnapCenter Server (SC) Issue After re-naming an SVM SnapCenter could no longer connect to the storage connection. Only occurs if SVM is not added on cluster level.
