NetApp Stage KB
SnapCenter Plug-in for VMware vSphere VM stops unexpectedly
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for VMware vSphere (SCV)
Issue
  • SCV does not clean-up log files properly which causes the VM to panic and the SCV services to fail.
  • Errors in the Maintenance Console:
    • Error in tempdir() using /tmp/XXXXXXXXXX: Could not create directory <dir>: no space left on device
    • Job for protectionservie-rbac.service failed because the service did not take the steps required by its unit configuration
  • Error seen in the SCV admin console:
vCenter Plugin connection has failed. VADP Server error occurred and SnapCenter Plug-in connection has failed. Failed to VMware plugin status: (Connection timed out). Please make sure the plugin is up and running
New to NetApp?
