NetApp Stage KB
SnapCenter Plug-in for SAP HANA does not locate hdbuserstore executable
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter
  • SnapCenter Plug-in for Unix
  • SnapCenter Plug-in for HANA
Issue
  • During the backup operation, the following error is found in the Hana backup log:
-bash: hdbuserstore: command not found
  • The GUI or Backup Report many also produce the following error:
exit code [-1] and with error: Verification of HDBSQL OS USER [snapcenter_hana] failed with error: [sudo: a terminal is required to
read the password; either use the -S option to read from standard input or configure an askpass helper]
New to NetApp?
